- Custom server authentication apps, such as JSON Web Token (JWT) apps, client credential app, and limited access app. These apps must be authorized by a Box Admin.
- Custom user authentication apps, such as OAuth 2.0 app. A Box admin may need to enable these apps depending on the unpublished apps setting.
- Open your Developer Console.
- Go to My Integrations and click the application you want to authorize or enable.
- Depending on the platform app type, go to Authorization tab for server authentication applications or Enablement for user authentication applications. IMPORTANT: The Enablement tab is visible only if a Box Admin enabled the Disable unpublished platform apps by default setting.
- Click Review and Submit.
Review the app details.
- If you are working in a sandbox environment, use the Publish Location section to select whether to publish in the parent enterprise or in the same sandbox.
- If you are using a production instance of the parent enterprise, you will not see the Publish Location section because the app is automatically published in the production environment.
- Wait for a Box Admin to approve your application. When this happens, you will receive an email with the details.
