Configuring File Restrictions
Admins and end users who have been enabled to use Box Forms can set allowed file types during the form design process. By specifying permitted extensions, you can tailor each form to accept only relevant documents, images, or other files as required by your organization.Supported File Types
| Category | Format(s) | |
| Images | .jpg, .png, .jpeg, .gif, .bmp, .webp | |
| Videos | .mov, .mp4, .avi | |
| Archive | .zip, .iso | |
| Documents | .pdf, .doc, .docx, .gdoc | |
| Spreadsheets | .XLSX, .XLS, .GSHEET, .CSV .xlsx, .xls, .gsheet, .csv | |
| Presentations | .ppt, .pptx, .gslides |
Setting Up File Restrictions
- Within Box Forms, open your form in the Box Forms editor.
- Drag and drop a file upload field or select an existing one.
- In the field’s settings, restrict the following:
- File Type:
- Images
- Videos
- Documents
- Slideshow
- Spreadsheets
- Archive
- Number of uploads
- Set a minimum or maximum limit for number of uploads.
- Note: If the file upload field is set to mandatory, at least one file upload will be required, even if the upload minimum is set to 0.
- File Type:
- Publish the form
- Validate the restrictions were implemented in the form.
