- Go to https://www.box.com/box-for-devices/ and download the appropriate Box Tools installer for your operating system.
- Run the Box Tools installer, and follow the prompts to install or update Box Tools on your computer.
- If you use the Safari browser (macOS only), you’ll need to perform the following additional steps:
- In main menubar at the top of the Safari window, click Safari then select Settings.
- In the Extensions tab, check Box Tools. If Box Tools is not listed, relaunch Safari and start again.
- In the Extensions tab, with Box Tools checked, click Edit Websites.
- Set Box.com to Allow.
