As a Box Admin, you can enable or disable Box Canvas for all your managed or selected users and groups.
Enabling Canvas
To configure Box Canvas, open the admin console and navigate to Enterprise SettingsContent and Sharing. Scroll down to the Canvas section. There are four configuration options available for Canvas:
  • Disable for all managed users,
  • Enable for all managed users,
  • Enable for select users and groups,
  • Enable for everyone except select users and groups.
canvas-configuration-png
Pick the option that suits your needs the most and save your changes. After saving, the option you chose is displayed next to the Canvas section in the admin console.
image-2023-04-19-11-04-00-098-png
You can change the configuration in the same section if necessary.
Note
Enabling Box Canvas for specific users has the following limitations: You can enter up to 100 names/email addresses and up to 100 groups. If you want to enable or disable more, you have to enable or disable Canvas for the entire organization.
