Box Docs home page
English
Search...
⌘K
Ask AI
Announcements
Announcements
Search...
Navigation
Using Box Sync
Using Box Sync
Home
Documentation
Box Sync
Homepage
Developer Portal
Support
Community
Overview
Using Box Sync
Overview
Logging in to Box Sync with WebView2
Uninstalling Box Sync Manually
Installing Box Sync
Marking Content for Box Sync
Modifying the Location of the Box Sync Folder
For Box Admins: Changing the Default Location for the Box Sync Folder
Unsyncing a Folder
About Box Sync
Deleting Synced Folders
Redirect My Documents Folder to Automatically Be Box Sync Default Folder Location
Setting Box Sync as a Default Save Location in Windows
Reinstall Box Sync on a New Computer
Using Box Sync To Link To Other Box Files
Using Box Sync
Using Box Sync
Cursor
Connect to Cursor
Cursor
Connect to Cursor
Installing Box Sync
Unsyncing a Folder
About Box Sync
Was this page helpful?
Yes
No
Box Sync
Previous
Next
⌘I
Assistant
Responses are generated using AI and may contain mistakes.
