There are four levels of permissions in Box Hubs: Admin, Co-Owner, Editor, and Viewer.
  • Admin can only enable Box Hubs for specific users/user groups.
  • Co-Owner has the broadest permissions.
  • Editor has the same permissions as a Co-Owner, except for creating and deleting a Hub, and managing Hub settings.
  • Viewer can’t make any changes to the Hubs they are invited to.
Below table lists all actions each of them can perform in Hubs.
AdminCo-OwnerEditorViewer
Enable Hubs for certain users or groups of users
See Hubs in gallery
Create a Hub
Delete a Hub
See Hub details page
Upload background and logo
Manage Hub users*
Manage Hub settings
Add/delete components
Move components
Save and publish the Hub
View the Hub
Share the Hub*
*These settings can be configured.
Notes
  • If you access Box Hubs through a shared link and you have an editor access to some files or folders, you can’t edit them from a Hub level. For more information on shared links, see Creating Shared Links.
  • Granting a user access to a Hub automatically gives them Viewer permissions to all files and folders in that Hub. This does not apply to external or Box links embedded in the Hub using Link Preview.
  • If a folder Uploader is invited to a Hub as Viewer, the folder Uploader permissions to the content change to Viewer/Uploader.
