Note
To run a report, you need to need to be an admin or have the co-admin permissions.
See Running Reports and Co-Admin Permissions Required to Run Reports for more information.
Box Hubs report details
- File format: comma-separated value (.csv) file
- Filename format:
hubs_run_on_YYYY-MM-DD-HH-MM-SS_[A|P].csv
Box Hubs report columns
In the generated Box Hubs report you can find the following columns:- Hub ID
- Hub Name
- Hub Description
- Creator ID
- Creator’s User Name
- Creator’s Email
- Created Date
- Number of Total Views
- Last Viewed
- Last Updated
