The Box Hubs builder provides an intuitive interface for organizing your Hub content. The builder uses the same interaction model as other Box tools, making it easy to learn and use.
Before you begin
To organize a Hub, you must have co-owner or editor permissions. For details, see Box Hubs Permissions.
Edit your Hub
To open a Hub in edit mode:
  1. Go to the Hubs gallery.
  2. Select the Hub you want to edit.
  3. In the upper-right corner, select Edit.
The Add Block panel appears on the right side. The panel displays all available content block types you can add to your Hub.
hub-builder-png
Content blocks
Content blocks are the building blocks of your Hub. Each block type serves a different purpose:
Block typeDescription
Files and FoldersAdd content from your Box account.
Section HeaderCreate an organizational section with a title (up to 100 characters).
ParagraphAdd text content (up to 5000 characters).
Call OutHighlight important information in a new call out window (up to 5000 characters).
Link PreviewEmbed interactive content directly in your Hub.
DividerAdd a visual separator between content.
Add a block
Use either method to add a block: Method 1: Click to add
  1. In the Add Block panel, select the block type.
  2. The block appears at the end of the page.
Method 2: Drag to add
  1. In the Add Block panel, drag the block type onto the page.
  2. Drop it in the desired location.
Manage blocks
To manage a block:
  1. Select the block on the canvas.
  2. The context toolbar appears with available options:
    • Move up or down
    • Move to a Different Page
    • Duplicate
    • Trash
    • Add Items (for Files and Folders blocks)
    • Display as grid or list (for Files and Folders blocks)
    • Formatting toolbar (for Paragraph and Call Out blocks)
To reposition a block, select it and drag it to the new location.
In Files and Folders blocks, individual files become draggable only after you select the block. This prevents accidental movement.
  • List view: Drag and drop files or folders to reorder them.
  • Grid view: Select a file or folder, click the (three dots) at the bottom of the card, and click the Move Left or Move Right arrow.
Delete a block
  1. Select the block.
  2. On the context toolbar, select Trash.
Sections
Sections help you organize related content by creating visual separators on your page. Each section title marks the beginning of a new section.
Create a section
  1. In the Add Block panel, select Section Title or drag it onto the page.
  2. Enter a section title (up to 100 characters).
  3. Add content blocks to your section.
When you add a section title, an outline is created automatically in the Hub navigation. This makes browsing easier for viewers.
Reorder sections
  1. Select the section title.
  2. In the context toolbar, select Move Up or Move Down.
  3. Move the section to the desired position.
Rename a section
  2. Enter the new title.
Delete a section
  1. Select the section.
  2. In the context toolbar, select Trash.
Pages
Pages provide another level of organization in your Hub. You can create multiple pages and nest them to build a clear hierarchy.
Add a page
  1. In the Hub Outline panel, select Add Page (+).
  2. Replace the default title with your page name.
The default title format is “Untitled Page [yyyy-mm-dd hh:mm:ss].”
Add a nested page
Nested pages (subpages) appear under a parent page in the hierarchy.
  1. In the Hub Outline panel, hover over the parent page.
  2. Select the ellipsis (…) to open the page options.
  3. Select Add Nested Page.
  4. Enter a title for the nested page.
Duplicate a page
  1. In the Hub Outline panel, hover over the page.
  3. Select Duplicate Page.
Change page hierarchy
You can reorganize your pages at any time:
  • Reorder pages: Drag a page up or down to change its position.
  • Create nested pages: Drag a page onto another page to make it a subpage.
  • Promote nested pages: Drag a subpage into the main page area to make it a top-level page.
Your home page is always the highest page in the hierarchy and can’t be moved.
Delete a page
  3. Select Delete Page.
  4. In the confirmation dialog, select Delete.
When you delete a page, all content within it is deleted, including blocks and nested pages. This action can’t be reversed.
Notify collaborators of changes
After you make changes to your Hub, you can notify all collaborators through email.
Send a change notification
  1. Make your changes to the Hub.
  2. In the upper-right corner, select Save > Save & Notify Collaborators.
  3. In the notification dialog, enter a message describing your changes.
  4. Select Save & Notify.
All Hub collaborators receive an email notification with your custom message and a link to open the Hub.
Save without notifying
If you don’t want to notify collaborators:
  2. In the upper-right corner, select Save.
Your changes are saved, but collaborators don’t receive an email notification.
