Box Docs home page
English
Search...
⌘K
Ask AI
Announcements
Announcements
Search...
Navigation
Administering and Configuring Relay
Home
Documentation
Box Relay
Homepage
Developer Portal
Support
Community
Overview
About Relay
Overview
Introducing Box Relay
Relay Features in Box Business Plans
Managing and Tracking Workflows
Overview
Transferring Your Workflow to Another User
Tracking and Downloading the Progress of your Workflows
Managing and Modifying Your Workflows in Relay
Overview
Enabling Box Relay for your Organization
Reporting on Relay Usage in your Organization
Building Basic Workflows
Overview
Understanding Triggers and Outcomes in Relay
Envisioning a Workflow in Relay
Creating a New Workflow in Relay
Using Templates to Build Workflows Quickly
A Sample Workflow - Marketing Campaign Budget Approval
Building Enhanced Workflows
Overview
Creating and Running a Manual Start Workflow
Routing your Workflow when a Task is Rejected
Starting Relay Workflows Automatically with File Request
Generating Documents with Box Doc Gen and Box Relay
Creating and Using Your own Custom Workflow Templates
Cursor
Connect to Cursor
Cursor
Connect to Cursor
Was this page helpful?
Yes
No
Previous
Next
⌘I
Assistant
Responses are generated using AI and may contain mistakes.
