Box Docs home page
English
Search...
⌘K
Ask AI
Announcements
Announcements
Search...
Navigation
Deploying and Managing Box Drive
Monitoring Box Drive Adoption
Home
Documentation
Box Drive
Homepage
Developer Portal
Support
Community
Overview
Getting Started with Box Drive
Overview
Hiding files and folders in Box Drive
New Box Drive for Windows: Built on a New Architecture
About Box Drive
Installing and Updating Box Drive
Using Box Drive Basics
Understanding Permissions When Moving Content in Box Drive
Making Content Available Offline
Managing Hard Drive Space When you Mark Content for Offline Use
Using Box Drive in Multi-User Environments
Box Drive for Google Workspace
Uninstalling Box Sync Using Box Drive
Switching from Box Sync to Box Drive
Uninstalling Box Drive
Overview
Enabling Known Folder Redirection on Windows
Large Scale Deployments: Box Drive
Technical Information for Box Drive Administrators
Enabling Box Drive for Your Users
Configuring the Default Box Drive Folder Location (Windows Only)
Enabling Enhanced Lock/Unlock on Box Drive (Windows Only)
Enabling the Mark for Offline Feature for Your Enterprise
Cursor
Connect to Cursor
Cursor
Connect to Cursor
You can review which of your users have logged into Box Drive by running a
User Activity
report and filtering for the Activity Type
Add login app
under the
Login
section. Export this report, then filter the
Affected
column by
Box Drive
Was this page helpful?
Yes
No
Previous
Next
⌘I
Assistant
Responses are generated using AI and may contain mistakes.
