This article contains recommendations and considerations for administrators who want to deploy Box Drive to many computers.
Box Drive and other Enterprise features
  • Box Drive supports Device Trust but does not support Device Pinning.
  • Box Drive’s activity will appear in the Admin Reports in the same way other application activity is logged. The comment Service: Box Drive will appear in the Change Details column of a User Activity report.  To learn how to generate Admin reports, see this article.
  • Box Drive also supports marking content to make it available offline. More information on enabling the mark for offline feature.
  • More information on Box Drive update behavior.
Migrate from Box Sync to Box Drive
Box Sync and Box Drive are two separate desktop applications that give you the ability to access Box content from your desktop environment. However, there are known issues with having both Box Sync and Box Drive installed on a single machine. And since Box Drive has nearly all of Sync’s capabilities — including the ability to work offline — and since it includes an automated Sync Uninstaller, it’s worthwhile, simple, and fast to transition fully to Box Drive. Start the Box Drive install process and Drive automatically uninstalls Box Sync and then cleans up your synced files. More information on installing Box Drive. When you install, you can also configure the default Box Drive folder location. And here are details on enabling Box Drive in your organization.
Windows
You can install Box Drive by downloading and running the Box Drive MSI. Before running the MSI, install the corresponding prerequisites listed below. There will not be a .exe installer for Box Drive.
Prerequisites:
See the Box OS support policy. See http://msdn.microsoft.com/en-us/library/windows/desktop/aa372024(v=vs.85).aspx for more information about performing silent MSI installs. Important Considerations:
  • Even with a silent MSI install, end users must login to Box Drive manually themselves.
Mac
Prerequisites:
See the Box OS support policy. Administrators can distribute the Box Drive PKG file to Mac users within their organization using standard application deployment tools. Alternatively, IT departments can install the PKG when imaging machines. Important Considerations:
  • You must log into Box Drive manually the first time you launch the app.
  • When installing Box Drive as the root user, all users on the machine must manually add Drive to their list of startup items
Box Drive Auto-Updates
Box Drive automatically prompts you to update to the latest version when an updated version is available. You can choose not to update, but we do not recommend using outdated versions, as Box supports only the latest version of the product. Get more information on the experience of updating Box Drive.
Box Drive in VDI Environments
For best results in virtual environments, we recommend persisting LocalAppData\Box\Box
Box Drive Technical Information
For more detailed technical information on Box Drive’s caching behavior and local storage usage, please review this technical information for Box Administrators.
Box Drive General Limitations
For more information see Box Drive’s known limitations.
