- Root level: You can move only those root-level folders for which you are the Owner. Just as in the web browser, dragging a folder that you own into a folder somebody else owns replaces you as the owner of that folder.
- Below the root level: You can move files and folders around according to your permission level in Box.If you attempt to make changes to a file or folder in which you only have viewer permissions, your changes will not be saved to Box, and will be reverted on your local machine automatically. In some cases, these files may be marked with a problem file notification.
- Content with preview-only access will not be downloadable via Box Drive. Instead, this content can be viewed by right-clicking on the content and selecting View on Box.com.
| Folder Level | Owner | Co-Owner | Editor | Viewer | Previewer |
| Root (Top) Level | ✔ | x | x | x | x |
| Below Root Level | ✔ | ✔ | ✔ | ✔* | x |
Note: To copy the item, hold down the Option key.
