In Box Drive, you can hide files and folders from your view in Explorer/Finder to show only relevant and necessary items. When you hide a file or folder, it disappears from your local Box folder tree, making it easier to find active work, but it remains in your Box account—securely stored in the cloud, available in Box.com and still searchable in Box Drive Important
  • Hiding files and folders does not:
    • Delete content or change collaborator permissions.
    • Remove content from Box. The content is still available on the Box website and through search.
    • Hide files and folders from other collaborators.
Requirements
  • Box Drive version 2.48 must be installed on devices
How Hidden Files & Folders Work
  • Personal and device-specific: Hiding a file or folder in Box Drive only removes, not delete, it from your Finder (Mac) or File Explorer (Windows) on that device. The item remains in Box and with collaborator visibility.
  • Still searchable and accessible: Hidden files and folders remain part of your Box account. They are hidden from view but still synced and cached on your local machine—not deleted. You can search their contents in Box Drive, appearing in the search results. Newly shared content will always show up by default—even if its parent folder is hidden.
  • Marked for Offline folders: If you hide a file or folder that is marked for offline access, it will still be updated whenever you are online and remain available when offline. Hiding the file or folder helps clear up your item view—it does not affect its availability when you go offline.
Hiding a File/Folder with Finder/Explorer:
To hide items:
  1. Open Finder (Mac) or File Explorer (Windows)
  2. Right click on the item
  3. Select Hide this Folder or Hide this File.
Hiding or Unhiding Folders/Files through Preferences
Windows:
  1. Open Box Drive Preferences via:
    • System tray Box icon → Gear icon → Preferences
    • Keyboard shortcut: Ctrl + Shift + Alt + B → Gear icon → Preferences
    • Right-click system tray Box icon → Preferences
  2. Navigate to folder visibility settings within Preferences.
macOS:
    • Click Box icon in menu bar → Select gear icon → Preferences
  3. Click “Change Selection…” button
Changing Box Drive Hide/Unhide Preferences
Opening the Preferences menu displays a list of your Box folders and files:
  • Checked folders - visible in Box Drive.
  • Unchecked folders - hidden in Box Drive.
To Modify:
  1. Uncheck the box for any folder/file you want to hide.
  2. Check the box for any folder/file you want to unhide (make visible).
  3. Click Done to save changes.
Searching Hidden items and Unhiding from Box Drive
On Windows
  1. Click the Box icon in the system tray/menu bar
    1. Alternatively: Use Ctrl + Shift + Alt + B.
  2. To search all of Box Drive, type your keywords — results appear as you type.
    1. Within a specific folder:
      1. Click the Search inside a Folder icon
  3. Right-click the item and click Unhide File or Unhide Folder; item will reappear in the File Explorer
hidden-content-in-search-results
On Mac
  1. Click the Box icon in the menu bar to open the search bar
    1. Alternatively: Use Ctrl + Option + Cmd + Space
  2. Search for the item
  3. Right-click the item and click Unhide File or Unhide Folder; item will reappear in Finder
Known Issues
  • Partially hidden folder states do not persist after closing the Preferences menu. The correct visibility restores when you next navigate to a hidden item.
  • On Mac, Hide This Folder/File context menu option does not appear for some items.
    • Select Refresh File/Folder, then Hide This File/Folder will appear.
