Box Docs home page
English
Search...
⌘K
Ask AI
Announcements
Announcements
Search...
Navigation
Organizing and Tracking Content
Understanding Folder Icons and Colors
Home
Documentation
Box Fundamentals
Homepage
Developer Portal
Support
Community
Overview
For Users
Overview
User Login and Settings
Getting Started
Collaborating
Staying organized
Overview
Managing Files and Folders
Overview
File and Folder Badges
Accessing Version History
Accessing Commonly-Used Web Integrations in Box
Tracking User Activity on Files
Tracking User Activity on Folders
Using Metadata
Using Tags
Cascading metadata in folders
Using the Box Task Center
Creating Bookmarks
Sort Files and Folders
Tracking File Activity in Different Applications
Using Keyboard Shortcuts for Box
Using the Box Notification Center
Using Recents
Installing the Integration Activity Stream in your Enterprise
Installing App Activity for Box for Salesforce
Understanding Box File Timestamps
Using the API to add metadata to multiple files
Previewing Content
Uploads and downloads
For Admins
Overview
Getting Started
Collaborating
Staying organized
For Users
Staying organized
Cursor
Connect to Cursor
Cursor
Connect to Cursor
Folder icons differ based on folder owner and collaboration status. For more information on folder permissions,
check out this article here
Frequently-used icons are identified in the following table:
Icon
Description
Personal folder
Owned by: You
Color: Manila
Collaborated folder
Owned by: Someone within your enterprise
Color: Blue
External collaborated folder
Owned by: Someone outside your enterprise
Color: Grey
Was this page helpful?
Yes
No
Previous
Next
⌘I
Assistant
Responses are generated using AI and may contain mistakes.
