- adds that instance and its values to each of the folder’s files and sub-folders, and
- propagates edits of the template to every instance of that template in the folder.
Note
- To request enablement of this feature for your enterprise, please contact your admin.
- If you’re an admin, learn how to enable this feature here.
- In your Box window, hover on the folder.
- Click ”…” or press the mouse’s right button.
- Hover on More Actions and select Metadata. Box displays the Metadata window.
- In the top of the Metadata window, click Add and select a metadata template. Box displays the template’s name in the Metadata window.
- Click the edit icon beside the chosen template’s name. Box displays the metadata editing window.
- Edit the instance’s attributes, if you wish.
- Click the Enable Cascade Policy slider button. Box displays the conflict resolution pane.
- In the conflict resolution pane, click the resolution policy you want to enforce.
- In the bottom of the metadata editing window, click Save.
Note
- To stop a cascade policy, again click the Enable Cascade P****olicy slider button. After you stop a folder’s cascade policy, new content added to the folder does not automatically inherit the cascade policy.
- Metadata values within files and sub-folders persist after the cascade policy is stopped.
- Enabling the cascade policy applies metadata via an offline process. Performance varies based on the size of your folder hierarchy, and system load.
FAQ
Cascade Behavior
If I add a cascade policy to a folder, are the metadata values applied to all sub-folders? If a cascade policy is applied to a folder, all files and folders receive the metadata template and its values. An additional delay may occur for files applied to folders with a long sub-tree path. What happens if my file already has metadata on it? If I move this into a folder with a conflicting cascade policy, is this information overwritten? Metadata cascade policies do not overwrite any existing metadata - we don’t want to delete customer data without the right notification. If a conflict occurs, existing metadata values persist on the file. If you want to overwrite the existing metadata, you can use the force-apply metadata cascade policy to force all metadata within that folder to have that folder’s metadata. What is the expected time from file upload to metadata cascade? Applying metadata via the cascade policy is not an immediate action, and may take some time depending on the size of the folder structure. Can I cascade only certain attributes of a metadata instance? No, we only support the cascading of an instance in its entirety. However, you do not need to fill in all attributes in order to cascade. Can I cascade an empty metadata instance with no values? Yes. How do I remove a cascade policy? While in edit mode, simply turn off the cascade toggle. This turns off only the policy itself, meaning net new content (without conflicting instances) moved into the folder does not automatically inherit the cascade policy. Metadata values within files and sub-folders still persist even after the cascade policy is deleted. How do I un-cascade the instances that I’ve previously cascaded? Currently, no option is available to undo instances that have been cascaded down to sub-files and folders. If you want to remove the instance, you must remove instances from individual files and folders.Moving and Copying Content
If I move a file outside of a folder, does the metadata stay with the file, or does it disappear? Metadata remains with the file, no matter where it is moved. What happens when I move a file or folder to a folder with cascade enabled, and there are no conflicts to metadata instances and their attributes? The file or folder that’s moved into the folder with the cascade policy enabled inherits the instance and its attributes. What happens when I move a file or folder to a folder with cascade enabled, and there is a conflict? If a file has the same metadata template applied, then the cascade policy skips that file. If you want to overwrite existing metadata instances and values, select the Overwrite all existing template values within the cascade conflict subsection, and re-apply the policy. Note that you’ll need to be in edit mode, and may need to first toggle the policy off and back on to see the conflict subsection.
