- Feedback is dispersed across emails and other chat tools
- Comments are not in-line, so it’s unclear what content a comment is referring to
- Reviewers need to open the app the file was created in to leave comments
- Open the file in Preview on an Android phone.
- Tap on the annotations icon at the bottom of the preview screen to open the annotations toolbar. You will see a set of tools appear.
- Next, select the highlight region tool.
- Tap and drag anywhere on the file itself to draw a box.
- After lifting your finger, the comment field will appear by default. Add a comment and tap “Save”.
- Next, select the highlight text tool.
- Tap and drag on a section of text within the file itself to highlight it.
