To speed up your work, Box also enables you to select multiple files so you can perform bulk actions with drag-and-drop.
Note: To move content into Box, you must have the necessary folder access and folder write permissions. If you do not have the necessary permissions, contact the folder’s owner.
Using drag-and-drop to upload content to the Box app
If you have access and write permission, you can move files from your iPad device or a mobile app into the BoxFiles directory, or move the items directly into a destination folder. Box then uploads your items automatically. To upload content to the Box app:- On iPad, touch and hold the item you want to upload to Box. The item can be single or multiple files.
- Drag the item onto the Box app icon and release. Box asks you to choose the destination.
- Select where you want to put the item.
- Box adds the item to the destination.
- Drag the item onto an open Box window and over your chosen destination folder, then release.
