- Scan an unlimited number of pages of text and convert the scanned pages to PDF format.
- Edit individual pages by adjusting the cropping, color scale, or rotating the image.
- Delete individual scanned pages.
- Search for text within the scanned image, or search for the scanned document using keywords as part of file search.
| Document Scanning Feature | Box App (Android) | Box App (iOS) | Box Capture App (iOS) |
| Auto-detection of image corners | ✅ | ✅ | ✅ |
| Auto-scan | ✅ | ✅ | ❌ |
| Manual scan | ✅ | ✅ | ✅ |
| Cropping | ✅ | ✅ | ✅ |
| Color scale options | ✅ | ✅ | ✅ |
| Text recognition via optical character recognition | ✅ | ✅ | ❌ |
| Searchable text | ✅ | ✅ | ❌ |
- In the Box Browse tab, tap the + button.
- On iOS, tap Scan Document. On Android, tap Capture Media then Scan Document. Box opens camera mode.
- Hover your camera over text.
- When the camera detects the document, Box automatically captures the image. Otherwise, you can manually capture an image by tapping the shutter button at any time. Box enables auto-scan by default.
- Box displays the captured image in the Preview screen.
- On the Preview screen, you have the option to either retake the image or keep the image.
Converting images to PDF
After scanning a document, you can convert its image into PDF. To save and convert to PDF: When you have captured at least one image and are in camera mode, Box displays a Save button.- Tap the Save button. Box converts the captured images to PDF, and saves the scanned document to Box.
Editing a scanned document
To edit:- When an image is stored and you are back in camera mode, at the bottom-left of the screen tap the image. You have the option to edit or delete the captured image.
- Select the edit you want to perform.
- On iPhone and Android, at the bottom of the Edit screen tap the action you want to perform.
- On iPad, at the top of the Edit screen tap the action you want to perform.
- After making edits, tap Done.
Searching
After uploading a scanned document, you can search it for keywords. You can also search for scanned images in folders. To search for words within a scanned document:- When the scanned document has been uploaded, go to the File Preview screen and at the top of the screen tap the magnifier icon.
- In the Search field, type keyword(s).
- If Box finds keywords, Box displays the search results.
- In the Box Browse tab, tap the magnifier icon.
