Display modes
When displaying the preview of a page, Box uses one of two display modes: Fit to Width or Fit to Screen.Fit to Width
This is the Box default option. When you open a document on your mobile device, Box fits the page to the width of your device’s screen, and enables you to- scroll up and down through the page, and
- scroll to the previous or next page.
Fit to Screen
When you open a document on your mobile device, Box fits the full page onto your device’s screen, and enables you to- see the entire page without scrolling, and
Selecting display mode
To select how Box Preview fits the displayed page to the screen of your mobile device:- In the top-left of your Box account’s screen, tap your avatar to go the the Settings page.
- Tap File & Folders and then Page Display.
- Tap:
- Fit to Width (default) - To fit the page to the width of the screen. Afterwards, depending on the aspect ratio of your mobile device’s screen, you may need to scroll through the displayed page to see its entire contents.
- Fit to Screen - To fit the entire page onto the screen. Afterwards, you’ll be able to see the entire displayed page without scrolling.
