When you’re
  • uploading or downloading a file or folder,
  • moving or copying a file or folder, or
  • marking for offline access a file or folder,
the status-and-transfers icon at the top of the screen displays the current progress of the action. The status-and-transfers icon also enables you to cancel the action, retry a failed action, or retry an action that returned an error.
jobsstatus-png
To see the detailed status of the action: tap the status-and-transfers icon. To Cancel or Retry the action:
  1. Tap the status-and-transfers icon.  Box displays the status window.
  2. Beside the file or folder name, tap the loading icon and select the option you want to perform.
