Signup and Login
This section allows you to set up options for managed users to create accounts and sign in.Multi-Factor Authentication
This section allows you to define requirements for multi-factor authentication (MFA) and 2-factor authentication (2FA), or 2-step verification, for managed users and external users who login with a username and password. (This MFA setting is not available if you use single sign-on (SSO) because in that case, multi-factor authentication is configured by your SSO provider.)Managed Users
External Collaborators
Password Requirements
This section allows you to define password requirements.NoteIf your enterprise account is SSO-enabled, these password settings apply to a user’s external “Box-specific password,” not the user’s SSO password. This is also where you can require strong passwords for external collaborators.
