- For high-level information, go to Admin Console > Account and Billing. In the Usage section, you will see:
- The total amount of storage your organization uses currently, and, if your organization has a limit on the total amount of storage it is allowed to use, that amount also. (This allows you to see if you are approaching your limit; you can reach out to your support representative if you require a higher limit.)
- The amount of upload bandwidth, download bandwidth, and total bandwidth consumed by your organization during the current calendar month.
- For details about the storage your organization uses, go to Admin Console > Insights and view the Storage tile.
- For details about the bandwidth your organization consumes, go to Admin Console > Reports and run a Bandwidth Usage by User or a Bandwidth Usage by Files and Folders report.
