Note: End of Life (EOL) has been announced for Box Sync effective
December 2026. For more information visit the
official announcement page.
Windows:
(See the Box OS support policy for details.) You can install Box Sync by downloading and running the appropriate Box Sync MSI. Box Sync 64bit MSI (Link removed by EOL) See http://msdn.microsoft.com/en-us/library/windows/desktop/aa372024(v=vs.85).aspx for more information about performing silent MSI installs.Mac:
Administrators can install the Box Sync DMG file (Link removed by EOL) for Mac users within their network. Deployment differs based on the bootstrapper installation. View the /Library/PrivilegedHelperTools/ directory to check if the com.box.sync.bootstrapper bootstrapper is installed. If the bootstrapper is already installed in the user’s system, the user can download and run the Box Sync DMG file at a later time without requiring administrator access. If the bootstrapper is not installed in the user’s system, follow this process:- Copy the application bundle to the desired install location on the user’s machine.
- Copy the bootstrapper from the application bundle to /Library/PrivilegedHelperTools/.
- Run the following command at the root level: sudo <path to bundle>/Contents/Resources/com.box.sync.bootstrapper —install
