NoteOutbound Activity and Security Logs reports, as well as reports not run from Reports, Legal Holds and Retention reports, cannot currently be scheduled.
- If the report filters include a date filter, such filter allows you to include data from a selected time frame.
For example, a scheduled monthly report set to start on July 1st with a date filter of Last Month will include data for June 1st - July 1st. Next month, it will run on August 1st and include data from July 1st - August 1st. - If the report filters do not include a date filter, the report provides a snapshot of data as of the day it is run.
For example, a scheduled monthly report set to start on July 1st will provide data as of July 1st. Next month, the report will include data from August 1st, and so on.
- A report with the start date of May 31 will run on June 30, July 31, and so on.
- A report with the start date of January 31 will run on February 29 in a leap year or February 28 in a common year, and then on March 31, April 30, and so on.
- Create a report as described in the To run a report that can be scheduled and its configuration saved procedure in Running Reports.
Enable the Save these settings to use in the future switch in the Save Report Filters section.
- Enter a name for the saved report configuration.
- Click Schedule report.
Specify the timeframe when the report will run:
- Start date specifies the date on which the report will be run for the first time.
- Repeat Every specifies the time interval. You can choose your report to run weekly, monthly, yearly, or once only.
- End date to specifies when is the last day the report will be run.
- Click Save.
- Click Schedule.
