Retention Tab
The Retention tab is where you configure content retention policies. Retention defines how long content is kept even if it has been put in Trash. Content cannot be permanently deleted, even if it is in Trash, if it is under retention policy and the retention time has not expired. This section lists the settings for retention policies and describes each setting. Select from:- Content within specific folders to retain content within specific folders. When you select this option, you will select one or more folders in the next step of retention policy creation. Once the policy is enabled, it applies to, or is cascaded to, all content in the selected folder(s), all files and everything in every sub-folder.
NoteOnce a retention policy is applied to a folder, if any
file or sub-folder is moved out of that folder, the retention
policy still applies, and that holds true no matter where
the move or how often the move. The one exception is
that if a file or folder is moved into a folder where
a retention policy with longer retention is defined,
that that policy is then applied to the moved file or
folder.
- Content with specific metadata to retain content based on content metadata. When you select this option, you will select one or more metadata options in the next step. If you select multiple metadata options, the retention policy will be applied to content that matches any of the selected metadata.
- Content with specific classifications to retain content based on classification labels applied to that content. When you select this option, you will select one or more classification labels in the next step. If you select multiple classification labels, the retention policy will be applied to content that has any of the classification labels applied.
NoteOnce a retention policy is applied to a file based on
that file having a classification label, if the classification
label is changed (or removed), the retention policy still
applies to the file.
- All new content to apply the retention policy to all future content added or uploaded to Box while the retention policy is active.
- 30, 60, or 90 days
- 1, 3, 6, or 10 years
- A custom number of days or years
- An indefinite period of time
NoteThe Permanently delete content option is not available if the People who can permanently delete content in Trash setting in Enterprise Settings > Content & Sharing > Trash is set to Nobody (No user or policy can delete content).
NoteSome email clients truncate large messages. In those cases, recipients
of these notifications may need to click a “View all” or “View
entire message” in their email client to see the entire list
of files if the list is long.
Legal Holds Tab
The Legal Holds tab tab is where you configure content legal hold policies. Legal holds define what content is kept and (optionally) for how long even if it has been put in Trash.Legal Hold Policies
This section lists the settings for legal hold policies and describes each setting.Legal Hold Exports
This section lists the settings for legal hold exports and describes each setting.NoteWhile the date range determines which files get included in the
export, it is the latest version of those files that are exported.
