- Add, change, or delete MFA (multi-factor authentication) settings for both managed and extenal users
- Enable or disable the SSO Required setting
- If the Admin or Co-Admin is enrolled in MFA, they will be presented with the challenge based on their authentication method.
- If the Admin or Co-Admin is not enrolled in MFA, they will be presented with an email MFA challenge. At this stage, upon completing the challenge successfully, they will NOT be enrolled in MFA.
- If the Admin or Co-Admin is SSO enabled, they will be presented with an email MFA challenge.
NoteAfter you enter an MFA challenge correctly, there is a 15-minute grace period in which you can perform other critical actions and not get another MFA challenge.
